can I ask something
Results 1,891 to 1,920 of 2222
MeGUI x265 encode with ffmpeg (lav filter) or something else ?
I hope you understand -
In general, x265.exe will only produce an elementary HEVC video stream. It will have to be multiplexed into an MP4 or MKV or M2TS container to be paired with an audio stream. There are several different possible tools to do that. MeGUI will prefer separate tools like mkvmerge or MP4Box. But ffmpeg can do that already while encoding. There are GUIs based on ffmpeg which can work on different operating systems; AviSynth only exists for Windows so far, but is much morre flexible, more powerful filtering the video before it gets encoded.
New year, new build... new feature:
Code:--[no-]rd-refine Enable QP based RD refinement for rd levels 5 and 6. Default disabled
x265 1.8+201-769081eb5f4c (GCC 4.9.2)For each analysed CU, calculate R-D cost on the best partition mode for a range of QP values, to find the optimal rounding effect. Default disabled.
Only effective at RD levels 5 and 6
x265 1.8+201-769081eb5f4c (GCC 5.3.0)
BTW, x265 v1.9 is coming soon. Do we still need GCC 4.9.x builds? Or is GCC 5.3.0 the currently "best" GNU C/C++ compiler version?Last edited by LigH.de; 9th Feb 2016 at 05:48.
Due to a few important bug fixes, and a "merge with stable":
x265 1.8+205-d94f6c2b45f8
GCC 5.3.0 only from now on (LoRd_MuldeR reported in the doom9 forum that they are noticably faster, and in general reliable). -
A few more bugs fixed, and merged with stable:
x265 1.8+212-792f6ead9c50 -
Again, a "weekly" build with bugfixes; merge with stable.
x265 1.8+221-f548abe8eae8 -
Only few more fixes for the new milestone:
x265 1.9+3-548a45bbf223 -
I am sorry to disappoint you. As far as I remember, there is a reason that v1.8+2 was preferable, I believe due to the structure of the default vs. stable branch around this milestone.
Furthermore, I just removed my MSYS environment with GCC 4.9.2 — so...
And I see no reason in producing a revision as exactly as possible (which will probably lack of a dozen changes if you went back these 2 patches). Why this effort? Only to feel some kind of happiness ... or for technical reasons? -
How I build my binaries
- Download the current precollected MSYS environment from Xhmikosr's tools (or in your case, because you insist in an obsolete compiler version: MSYS_MinGW-w64_GCC_492_x86-x64_Full.7z)
- Unpack to a convenient location (rather not inside %ProgramFiles%)
- Create a link to the included msys.bat and edit it so that the command line reads: directory\msys.bat --mintty
- Run this link once and close with the command exit
- Navigate to the subdirectory home\useraccount in your MSYS installation and unpack the attached archive with my build scripts.
- Run in this order inside your MSYS mintty shell:
- hg clone https://bitbucket.org/multicoreware/x265 (as documented in the x265 Wiki, to get the sources for the first time)
- ./uptodate_x265.sh (this prepares a few subdirectories and updates to the "tip" revision, depending on what's missing)
- If you wanted to use not the tip, but a specific revision instead, you would change to this revision with e.g. hg update --cwd x265 -r 1.8 to change to the revision tagged as "version 1.8", but this was in the "stable" branch, therefore you will lose several previous fixes, because the merge with the "default" branch was two patches later.
- ./remake_x265.sh (this compiles all separate executables and libraries with only one bitdepth)
- ./makemulti.sh (this compiles all multilib executables)
- ./release_x265.sh (this copies the results into a subdirectory /release from where I can easily archive them)
- Close the MSYS shell with exit and pack the release archive.
Once again: Preferring v1.8 over v1.8+2 is a rather stupid decision. But your choice.
Can you connect to the Team Viewer on my computer. You download the materials inside of my computer and builds 1.8. I record screen
Or you can video tutorial please. -
This thread is the tutorial -- please go to first page and click first link.
If you want to use GCC 4.9 build from stable branch right now -- you can download www.msystem.waw.pl/x265/x265-stable-gcc49.7z -
I suspect that eca2424 did not even try to follow my brief tutorial. This is not the right place for premastication, this is a thread for developers and experienced testers. Not for kids who cannot even explain why they want the pester power item.
@LigH.de Sir, I 'm just trying to learn. I try your brifing and follow this error; http://i.hizliresim.com/lvmA5E.png
Alright ... thank you for taking the challenge.
Your error probably means that you forgot to unpack the archive "x265_buildscripts.zip" (attached to the posting above) into your MSYS home directory. It contains the shell scripts which are reported to be missing in your screenshot.
You also missed to use "mintty" as shell; it is superior to the basic "sh" shell. I recommended to create a link to the msys.bat (e.g. on the desktop) and edit this link, so that it is executed with a parameter. Not absolutely necessary, but very recommendable. -
No I did not forget;http://i.hizliresim.com/1MqR1A.png
is that right place x265;http://i.hizliresim.com/A5Wjo0.png
is that right;http://i.hizliresim.com/nLZBV0.png -
Hmm, strange. The location of the scripts appears to be correct (in C:\MSYS\home\2016, not in C:\MSYS\bin). I don't know why they are "not found". Please show the output of "ls -l" in your shell; in mintty, "ls -Flash" should look even prettier.
And yes, the link seems to be correctly edited.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 07:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 23:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57
